So I borrowed my wife's car for a few days (jzx100) and she was using my stagea, she then said I have a little present for you but it isn't here yet and you can't look at the bank account because you will see where it's coming from.
So the last day we used each others car she came home late and gave me an envolope and said open it.
Inside was a card saying thank you and a dyno printout!
She stole my car, took it to classic performance (adelaide) got it nistuned, spitfire coils, new oxygen sensor and a full cat back exhaust!!
Car had 150kw when delivered now has 170 kw at all 4 wheels. Needs a better fuel pump for more power!
Best wife ever? Yep that's why I married her haha
So awesome!
So awesome!
Wow your a lucky guy!
So awesome!
Shit yeah; that's what it's all about. :thumbsup:
So awesome!
This story bought a tear to my eye.
Me too....if given my car for a couple of days my wife would burn it for a laugh....it's the only thing she hates more than me!!!!
My wife side swiped my stag with our new cx7
There was only one meter space between the two cars to fit past....
Is that the one they were advertising "with so many cameras you won't miss anything"?
If so, they need to add "even a parked Stagea"
My qutar window vents [what i guess you call them] started to flake so i decided rather then risk breaking them by pulling them of to respray i would cheat and plasti dip them insted [also alot cheaper seeing as i had left over and easier]
masked up and ready to go
removed rusty [the dog] from car and first coat done!
all done looks pretty good i think :whistling:
Just got my first S1 Dayz edition sent over from Brisbane after buying it off gumtree. It failed pits on not having a immobiliser and the suspension was under 100mm so its not road legal yet. It has BC coilovers so I spent spent a few hours winding them up yesterday to be legal. Then I washed all the horrible red dust off it from the truck ride and It came out looking pretty good. Is pretty much stock minus the mags and BC coilovers. It also has a "Nissan super exhaust" with nismo mufflers. Not sure if this was a factory option? The funniest extra it has is a luggage fan in the boot...
Just got my first S1 Dayz edition sent over from Brisbane after buying it off gumtree. It failed pits on not having a immobiliser and the suspension was under 100mm so its not road legal yet. It has BC coilovers so I spent spent a few hours winding them up yesterday to be legal. Then I washed all the horrible red dust off it from the truck ride and It came out looking pretty good. Is pretty much stock minus the mags and BC coilovers. It also has a "Nissan super exhaust" with nismo mufflers. Not sure if this was a factory option? The funniest extra it has is a luggage fan in the boot... IMAG0177.jpg
You gotta post a pic of the fan!
Nice looking wagon Ben, enjoy.
GW
I surprised mine with a surprise massage and a facial and a fancy beauty place last night. Try that you might get a full engine rebuild too lol
Your wife/significant other, or your car?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
