Added to the Steady growing stock pile
Purchased a 2nd hand Turbo via import Monster for a high flow upgrade, to prepare for the inevitable ceramic wheel failure.... (78000kms current)
Purchased the new Greddy Profec boost controller threw just jap (its been annoying watching the gauge and feeling the factory boost settings dropping of back to 7-9psi.)
Looking forward to installing all at once
Oil and filter this weekend, first car I have owned in which i changed oil on time instead of kays.
Used to doing 30+k a year, new job, new (old) car which wifey & young daughter get shaken up and now I'll be lucky if a crack 10k a year.
On the down side, found a ruined drivers inner CV boot and probably a dead breather in the gbox, I have a smurf bood dribble down the box...
Explains the gearbox oil smell after it gets a few revs.
Pain in the A though.
Added to the Steady growing stock pilePurchased a 2nd hand Turbo via import Monster for a high flow upgrade, to prepare for the inevitable ceramic wheel failure.... (78000kms current)Purchased the new Greddy Profec boost controller threw just jap (its been annoying watching the gauge and feeling the factory boost settings dropping of back to 7-9psi.)Looking forward to installing all at once
Nice! If you dont mind me asking - how much did the turbo set you back?
I installed my aux cable to the TV tuner on the weekend and replaced a few cracked vac hoses - not much, but its something!
Edited by Dmyze_
The last Hypergear turbo took a month, as Tao was in China. It's a very good idea if you can get one, although you will never get that sort of money back for them over here, not unless they are running perfectly.
Perhaps I can loan my spare out for a small fee? I would love to have a highflow on the shelf to help customers out, but I can't justify having $1300 tied up in a turbo sitting in the garage.
The Nm35 2nd hand turbo was $437.50 thats delivered to my place inclusive...
Today
Purchased Blitz catback exhaust...
Purchased R34 GTT RDC brand replacement cross drilled dimpled, slotted front rotors ill get the new callipers once I do a bit more research & bargain hunting...
roof racks mounted, rear cargo net also put on, not sure what it's supposed to mount down to, so just have it hanging from the room like a net
hopefully put the suspension in over the week, have so much to do :(
I fitted my replacement headlight in my sII and the light is poiting waaay to far down, tried to adjust it up with the screw and the electric adjustemnt fights me and just moves it back down...am i missing something here on how to adjust it up?
make sure that the globe is sitting correctly into the fiting it might be sitting up on one of the tabs
My mechanic relearned the throttle body. What a missiin that was. No body touch your throttle body (besides craig). I was unaware before and now after going through the mishap wouldnt recommend it to anyone. On a lighter not received the oem hids that I will be installing this week.
It is a bit of an epic if you don't get the timing of each step right, but a bit of practice gets it done.
You'll like the HID's. ;)
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
