Took the tractor for its first visit to the Dyno. I think it did alright with its stock turbo and 3 inch turbo back exhaust :D
">http://7I7CgA0.jpg
Not to shabby, what ecu are you using to tune it?
Good stuff.
So what's next?
Hopefully injectors and new turbo but will have to see how the funds go lol. I also have the classic faulty pressure switch causing the 4wd to come up so will have to deal with that at some stage too
mounted the fcon in the other little glove box thing
">http://yGhQlVt.jpg
  • Like 2
I have the same issue with the pressure switch, such a pain, I wish there was a reasonably priced fix for this
  • Like 1
Car got tuned today with an adaptronic, drives awesome now. The ss1 turbo ran out of puff unfortunately, so thats all we could get from it.
Looks good to me mate.
It may have run out of puff for chasing a higher number, but it would be my choice over a bigger (laggier) turbo any day. Probably faster everywhere bar a drag strip too :), at least where I live - hardly a straight road other than the freeway around here.
  • Like 3
Lucky I'm not in sa then and yes I did leave the windows down
No worries man. I could be wrong anyway
Just for some reason thought I would check it out there .
Obviously it's not that hot this time of year!
Written off due to to expensive to repair
same thing happened to me 2 weeks ago, got payed out friday.
Wife lost it in the hills, hit a oncoming car and went down a embankement through a fence, everyone was ok
thats my stagea ownership over, just going to buy a normal family daily this time...
cheers
darren
Edited by jet_r31
Fitted some tan leather 350z seat into my m35 today bolted up perfectly. Passenger side is a bit to low but will fit some spacers tomorrow. All the electrics and airbags are plug n play aswell :-D
  • Like 1
Now that is good to know.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
