So I fitted this over the last weekend.
I have looked at this brace a few times and wondered how much impact it would make. But I hadn't known anyone to do it to ask.
Have you done the OX rear bar and daleo front bar? If so did it have a similar change as they do?
Does it do anything?
It looks like it's supposed to attach to the body somewhere, but with the HICAS rack activated; I don't expect that would be a good idea at all.
So we took the car for a spirited driving on a motorway, long winding roads and back roads. All I can say is the handling is much improved overall, especially less twitching at the rear end. I do have the front underbrace and top strutbrace. I guess every little bit helps.
bought a cheap Greddy intelligent informeter touch, the touch screen is broken. ordered new touch screen from aliexpress.com and all sorted now.
Winning!
How cheap was cheap?
around $160-170. I saw some guys here bought new for $500?
I think mine was around $400 or so when I bought it several years ago (with good US exchange rate), so that's a damn good find.
I'm assuming the touchscreen was pretty cheap too?
touchscreen for $10-20 from China. actually i was not aware the touchscreen is dead when i bought it
  • Like 1
Taking a punt and ordering a Starter Motor for a 2003 LHD Infiniti from the US...
It mounts on the drivers side as oppose to the passengers so i am hoping it will work out for the manual conversion. The measurements look ok
Also measurements will be taken to get the tail shaft made up and then hopefully once the starter is on it will be a case of bolting everything back together with the 6sp from the 350z in place.
Clutch pedal still needs to be sorted and i havent even looked at centre console but i am hoping these are fairly straight forward.
Then will start the ECU head aches:p
(it's totally gonna be worth it)
Edited by Beregron
  • Like 2
Practical mods are the best kind, right?
Finally got the roof racks fitted to the stag, after the roof rack superstore stuffing me around for 2 weeks.
Both of the sunroof's still open which is nice, except its super noisy thanks to the racks. Might have to invest in one of those wind deflectors...if they actually work.
Will be fitting an awning to it in the coming weeks to, for the weekends away!
  • Like 2
what model number on the roof racks they look the goods and also them wheelz good stuff
Edited by stripey
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
