correct! that's what Greddy radiator breath tank do.
but for mine, the Apexi one, the bottom return line is connecting with heater hose outlet (it should be same as bottom of radiator hose). there is only one line on top which is to stock radiator top with zero pressure radiator cap.
next stage is using T piece replace stock air bleed port on heater hose inlet (i ordered some tools but they are on the way). then make a line from stock air bleed port with radiator top line together. that would make air bleeding be automatic.
(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0<d){for(var a=Array(d),c=0;c<d;c++)a[c]=b[c];return a}return[]};var m=function(b){var d=window;if(d.addEventListener)d.addEventListener("load",b,!1);else if(d.attachEvent)d.attachEvent("onload",b);else{var a=d.onload;d.onload=function(){b.call(this);a&&a.call(this)}}};var n,p=function(b,d,a,c,e){this.f=b;this.h=d;this.i=a;this.c=e;this.e={height:window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight,width:window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth};this.g=c;this.b={};this.a=[];this.d={}},q=function(b,d){var a,c,e=d.getAttribute("pagespeed_url_hash");if(a=e&&!(e in b.d))if(0>=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c<d.length;++c)a=a.concat(l(document.getElementsByTagName(d[c])));if(0!=a.length&&a[0].getBoundingClientRect){for(c=0;d=a[c];++c)q(b,d);a="oh="+b.i;b.c&&(a+="&n="+b.c);if(d=0!=b.a.length)for(a+="&ci="+encodeURIComponent(b.a[0]),c=1;c<b.a.length;++c){var e=","+encodeURIComponent(b.a[c]);131072>=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0<a.width&&0<a.height&&0<a.naturalWidth&&0<a.naturalHeight||e in b&&a.width>=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?app=forums&module=ajax&section=topics&do=quote&t=348629&p=7666165&md5check=6c7b695bfec134fd3073c29b47741d45&isRte=1,6YgIICLrb3,true,false,kri4IdftnM4');data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= Untitled.jpg
Have you got it hooked up with the bleed yet? Looks like a good mod. Is it an M35 specific kit or universal tank and you just buy he lines etc that you need?
firstly it is universal part, not specified for M35
here is the info from Apexi
secondly, for original design, it doesn't need to connect air bleed port due to Apexi thinks the radiator cap should be the highest point of the car. just bleed air from radiator cap using 0 pressure radiator cap.
the Apexi one came with 1* 19mm heater hose (for Apexi tank water return) and 1* 9mm water hose (to connect to stock overflow tank and radiator overflow port), 1* 19mm T piece (for return Apexi return water hose and stock heater return hose)
i make my own mod refer to Greddy one like below:
currently i changed the air bleed T piece with this one (from bunnings, due to the stock one is broken, LOL)
i blocked the top point by a block plug
i ordered this part on ebay and it is on the way
i could screw it to top of the air bleed port and using another 9mm water hose to connect to Apexi tank
here is the instruction and i will do the green part after i got above ebay part. just need to make sure the port on Apexi tank should be the highest one of car)
finally, i bought Apexi tank from yahoo auction due to the low price (around $130-140), RRP is over $200. i think you can buy faked Greddy one from ebay if you like, same design with smaller body, easy to mount in engine bay, but the most important thing is "it is really cheap"
http://www.ebay.com.au/sch/i.html?_odkw=coolant+breath+tank&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xradiator+breather+tank.TRS0&_nkw=radiator+breather+tank&_sacat=0
I bought the same tank, but couldn't find anywhere to mount it without hacking.
I could have made you an alloy version of that Bunnings part if you needed something with a barb. Not sure I would want to rely on that.
  • Like 1
What's the best way to "T" into the bottom rad hose? I doubt we can get one with the provision already there like you can for RBs etc
Edit: would probably just be a "water adapter" for whatever size our rad hose is? What size is our bottom rad hose? I take it you just cut a small section out and slip the remaining hose one other side?
Buy a remote water temp adaptor block (goes inline on rad hose) then tap to suit your chosen fitting.
Plumb line from bottom of swirl pot.
Profit.
water returns to stock heater return hose, that's 19mm
if you want to return to low radiator hose, that you could buy this:
http://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xnissan+water+temp+adapter.TRS0&_nkw=nissan+water+temp+adapter&_sacat=0
also you need to measure the hose inlet size before
yeah, we have narrow engine bay. i bought universal oil catch can but can't fit it.... i am looking at genuine 0.3L CUSCO catch can now.
also, i am going to mount another 12inch thin fan on left front for car, and using 2* 12inch thin fans together when AC is on. my car always get high temp when waiting traffic light/start and stop on 35degree day with AC on. if cruising, the temp will drop to 90.
Edited by YangLIU
Fitted my three under car braces, two sway bars, strut brace, calipers and MCAs.
post-135423-0-90931600-1453467367_thumb.jpgpost-135423-0-77239500-1453467379_thumb.jpg
Strut brace just fits over the engine cover.
post-135423-0-13244300-1453467547_thumb.jpgpost-135423-0-91024900-1453468833_thumb.jpg
Ended up removing the rotor backing plate completely rather than trimming, alternatively could have machined the inner rotor a bit.
Sway bars are same dimensions as stock but a heap heavier, front stock 3kg, Dolphin 7kg.
post-135423-0-59072800-1453467911_thumb.jpgpost-135423-0-12572900-1453468037_thumb.jpg
Rims ready to go on, just making some custom centre caps. Before and after.
post-135423-0-45464500-1453468140_thumb.jpgpost-135423-0-45134800-1453468196_thumb.jpg
and another project I picked up for $10 at the local tip/recycle yard. Going to knock up some brackets and cut out the mesh in the lower section for longer items with the seats down.
  • Like 1
^what car is that cargo barrier out of?
No idea, there was no make or part number just a generic Milford plate. I emailed them with pics and am waiting to hear back.
Yep, front and rear parking sensors on the car when I got it, you get used to the incessant beeping.
glad I don't have them in there rear of mine it shits me enough with just the fronts when people walk past at intersections. In Sydney f**ks pull up behind you so close I'd be murdering people all day if I had rear ones lol [emoji380][emoji380]
  • Like 1
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
