Got the following completed today ready for wheels tomorrow
- changed oil and filter
- replaced front inner passenger guard (grill due to transmission cooler in fro t of it to let heat excape)
- cleaned engine bay
- put the lower stone guards back under the front of the car
- finished securing Axis kit
- painted R34gtt front calipers black (yet to do silver 'NISSAN' writing
- placed spacer on exhaust so it clears kit70fba96b223414a91bfb5704af408dfb.jpge7176bddd3f9a300371b941f1c27eded.jpgdfb4aa956456a135d743585ef51abea3.jpg96f12d9fe38c063b4231f25877508790.jpg2a6161fa8529800f6a2d8ed588807374.jpg
Inspiration ..... added my to do list, the transmission cooler that is. Did you write up a diy somewhere?
Joined the Aero club, well in the front anyway..
Cut out the backs of the blank inserts to let air in, and to show off the polish pipe :)
That's it, I've finished her, and don't give me any more ideas.
  • Like 1
Either black out, or nip out the centre support in the meshed area (below the numberplate); it really cleans the bar up IMO.
The mesh and undertray are more than enough to support the opening without that spar.
13439023_10154287317847392_4871370956259
Painter did an awesome job with the matching. I was considering doing this to the blanks when i had it but these are too hard to find another set off did t want to ruin them at the time.
Looking good man for sure.
Checking battery voltage as bike one playing up lately. 12.2V before starting, charging at 14.4-14.6V, about 13 after shutdown, all good for now. Cranks over fine but we getting into cold weather now its not being used every day.
MY02 tyres at 5mm & 6mm after about 19500km, had them rotated at WOF time just because it was free. Wearing nice and evenly.
Didn't need a rebalance like the shop guy tried to sell me, have always done my own in past and no problems.
not much. I took off the emblems.
adhesive had a hard time getting away. had to grind finally got that bulges out
yet another label but later removed
Edited by TukeH
mahtava
  • Like 1
44 minutes ago, yuma said:
Finally got mine from compliance and got it regoed today. So damn happy with it. Gonna have to roll the rear fenders but. 2dacabbba7e70a8f84d768fe718b240a.jpg
350rx black with black leather.
very nice indeed, north or south?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
