Last weekend, my mate installed the BC BR coilovers on my ARX. Using out of the box height and dampening settings (for now).  Pulled out the Nismo springs which I'll put up for sale later on.
  • Like 1
Put her in for a safety certificate as she is currently being sold. (Sad couple of weeks ahead). Also need to replace roof lining and install the Greddy Profec B II i have sitting in garage for new owner.
Put on another rear wing.
The silver one was a bit short for my liking.
This one came 1350mm long which I cut down on my drop saw to 1220mm.
Gonna spray my mirrors black too.
Now I can carry sheet material on my roof :happy:
  • Like 1
no mate, they're off ebay
just relocated the mounts to suit the hatch, bolted through into the drain void.
filled and touched up the holes in the wing, underneath and so close to the roof you can't see them
mounted with sikaflexed rubber pads
Edited by conan7772
more info
  • 1 month later...
Replaced Greddy IGN chip with another one and hey it works, no CEL.
Had Jez replace my rocker gaskets, and while it was apart replaced my injectors.
I had 570cc "Denso Australia" reman injectors, and had terrible starts and poor fuel consumption. 360km to a tank./ 6km per litre.
These also had leak down.
Bought used R35 injectors and what a difference !
Car starts perfectly, economy way way better, 9km per litre, and my exhaust is 10db quieter.
I've been mucking around with silencers trying to get it under 100db with minimal restriction.
These shit injectors, give such bad atomization, hence why I was high risk of DET, causing loud exhaust tone.
Also don't have rough idle anymore, and that rasp in the rev range is almost gone completely.
Thanks Matt for the info.
  • Like 3
wow, no CEL anymore!
Hmm where the hell do I start...
So I found these three split hoses, one of which seems to have been taped up at some point on both ends because they had splits,
And the other one that goes into the cam cover broke clean out... but that also looks like it had some sealant stuff holding it in there (not sure if that's how it came from the factory)
So the whole mission was just to get to the spark plugs and coils.. who the heck made this process so long.
Here's a photo of where the hose broke out of, looks like it kinda just slotted in there without any thing holding it in?
I finally got to the coils and spark plugs, the coils looked fine and the spark plugs as I've been told looks like they are well used. So I think I'll go and buy some new spark plugs tomorrow because why not lol.
After all that I still don't really know why I'm getting that rough idle/misfire.
I'll get those hoses replaced and new spark plugs, and if that doesn't clean up this problem then I suppose coils will be next. But then again I might even just buy coils to be safe.
And just a photo with the "import" monster drink haha
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
