In the process of modification of the steering wheel into a flat bottom and top unit that retains the airbag.
Cut off the old foam in sections where changes are made, strengthened the construction and tig welded new sections in place, then carefully removed foam from a different model wheel to replace and reshape once urethane adhesive has cured
  • Like 3
Further progress on steering wheel mods.
Sanded to shape today, came up pretty good, well I think so anyway ha ha ha.
Now comes the expensive bit, first estimate for re-cover in leather was $400-500, so several quotes to come before finishing off.
Here's some dodgy pictures that give indication of size changes
  • Like 1
1 hour ago, KiwiRS4T said:
Good work - well done for keeping the airbags!
I like having insurance intact as well as maintaining a closer state of roadworthy ?
On 10/3/2018 at 5:04 PM, KiwiRS4T said:
Steering wheel is complete and fitted now, came up awesome with the new leather covering, line of sight to Guage cluster is nice unless you're a really short bugger, then it cuts off the top of speedo and tacho a touch.
Otherwise I'm wrapt in the results, feels nice in the hands, and gives ample leg clearance with the new recaro chairs now too.
  • Like 1
I changed the spark plugs and while I was at it decided the coil wiring was 30years old and brittle so why not go with some Yaris coils. I’ll see how they go with all the other mods if not I’ll change them to R35 ones later IMG_6754.jpg
  • Like 1
what loom changes etc were needed to be made? is there a tutorial on this somewhere perhaps? and what are the advantages please?
There’s a tutorial or here somewhere but I was a bit lazy and bought a kit from Golebys all I did was remove the original plug strip back the wiring and wired it into the factory plug so I didn’t have to cut the factory vehicle harness just the coil sub harness
The coils give a better spark and are a cheaper alternative to genuine style ones I’m looking to up the power a bit to around 400rwkw in the near future so with the harness and plugs needing replacement anyway I just fitted them now
  • Thanks 1
Guys, just make sure whatever coils you settle on that they're genuine. There's been quite a few reports that the yaris coils supplied by golebys aren't genuine Toyota. Im sure its been talked about on Sau before.
The kit came with everything needed I just needed to put the supplied pins on my harness I can’t remember exactly what I paid for the kit as I got injectors intercooler clamps plenum fuel rail fpr wastegates eboost as well
Installed a new head-unit with a rear aux since I was sick of the Raspberry Pi plugging into the front on the old one.
Also found that you can install RetroPie on OSMC so gave it a go! Great for dealing with Brisbane traffic :P
  • Like 3
decided to go with the 5-0 ignite Audi R8 coil conversion setup, ordered today so am hoping will be delivered by the weekend so can sneak them in on nightshift over the weekend if workshop isn't busy, only replacing splitfires as brains trust consensus is that the  engine has a suspected dodgy one firing intermittently at idle and mid range where car spends most of its rev-time, so because I subscribe to the old rule of if you are taking the time and coin to do one, you may as well do all of them, instead of having to go back and do it again later anyway, and after researching options and bang for buck etc, the Audi coil conversion was the middle ground costwise with the best plug-and-play setup coming in at a total of $710 delivered for all the bits, including 6x bosch coilpacks, mounting plate, brackets and wiring harness.
while I am at it I'll do a plug heat range change and re-gap to suit.
be interested if anyone else on here has done this conversion and the results, ease of changeover etc?
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
