Nah ah. GTR's are twins. Period. Its all about looking "stock" *ah hem*.... for when the super doods in their crazy SS's pull you over and say 'pop your bonnet son" :whistling: .
You sound like my tuner.... He calls twins "Thomas the tank engines" becasue they choof! Its all about no no no to singles and yes yes yes to twins haha
Sounds like a smart man lol
The thing with the V cam (as much as I would LOVE to have it on my car....as would all of us) is with the big one for turbo's like T04Z's, GT RS's is that you need valve relief pistons. I dont have that and I am not pulling down a engine to fit them! Its interesting that the -5's hold boost longer then the 2530's.
Your car made 440rwkw off the top of my head? That enough to scare most people :)
Yeah it was finally tuned to send to Oz at just over 600 PS (440kw) with a 8 second hit of an extra .2 Bar on the scramble boost.
Got to get it on the road first then look at E85 as got a petrol station that stocks it here thats about 500 metres away.
I still have a spare RRR block that you could build a new engine
Thats awsome. Lets see what it makes on E85!
A few little questions while im thinking of them.
Are you still using the factory CAS or did HKS use some sort of crank trigger unit? I am getting CAS noise above 6000 RPM or so.
Are you still using the factory airbox? I can't remember.
As for the block.... I already have one in my car.... It would be greedy to have 2 :thumbsup: haha.
Off the top of my head I'm pretty sure they used the factory CAS although they basically rewired the entire ignition system and ran 3 separate earth leads to ground points throughout the car.
Factory airbox.... Nope its got pods and all HKS piping
What do you guys think of the Midori front pipes?
I'm getting the Midori dumps which these match up to, then through to 90mm, but no flex join which I am a little worried about.
There doesn't seem to be anything else on the market to the same specs.
I was thinking about the midori fronts.... but if your going to have a 4 inch exhaust you might be better off with a set from racepace (IE Tangomatt's car, page 3)
Ash. Do you know if they would make up a set and sell them by themselves. From what Steve has told me they do business a little different to most places. I couldnt even find a phone number!
yeah they are good, but considering their price I would get the HKS ones. they are beautiful, have a flex joint, merge to single 90mm pipe and are twin 70mm (or more, can check this weekend if you like).
the HKS ones are about the same price.
That would be great if you have them handy thanks Richard. I can't seem to find details on the HKS ones online that merge to 90mm - nobody lists the specs.
Obviously with the Midori dumps at 76.3mm / 3" I am trying to get them to match without reducing.
I believe these are the ones your talking about:
HKS P/N: 1418-RN005
http://www.justjap.com/store/product.php?productid=16972&cat=&page=1
http://www.nengun.com/hks/extension-kit-gtr
Yeah strange how noone lists the dimensions??
HKS P/N: 1418-RN005
Nah they are the HKS dumps, it's the HKS front pipes that I am trying to confirm specs on - same deal nobody lists it.
Yeah I knew I had seen that somewhere - was just hoping that BB was referring to a different version as he mentioned there being 2 back in a previous post.
Sorry for the thread hijack guys, it is kinda related anyway - determining the biggest off the shelf front half exhaust.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
