some more progress.
secondary injectors will fit, took abit to get them sitting in the rite spot so they dont spray on to the runner and port walls and without putting the hole in the wrong spot to start with.
post-19586-0-94566200-1453540872_thumb.jpgpost-19586-0-17971500-1453540885_thumb.jpgpost-19586-0-26049500-1453540898_thumb.jpg
swaybar will need some modding
had some action in the backyard withe the next doors tree...
  • Like 1
no speed sensors. not really necessary. atmospheric conditions can change the boost given the same comp speed. i will be running a balance pipe on the back of the engine to average the boost to each bank.
just working out the heater/turbo plumbing atm. + water to air cooler plumbing+ our lease is up and have to move.........
secondary injectors all mounted.
It looks schmick, nice job. But why go to staged injection when you can run injectors up to 2000cc that will idle and run nicely down low as well?
If it's bling, I understand. But the work / complexity increase would make me shy away.
because i want it to pass an im240 if need be. my ecu can run it, and with proper injector placement i wont need as big. better economy and more consistent mixtures.
ive got a set of moran billet atomisers that will do the job, but i want it done well. fyi the "2000 ish cc" injectors on the market are gas injectors and fail on a regular basis. there not meant for liquid petrol. let alone e85. the rubber seals inside swell and change there dynamic flow rate.
yes some updates. having our lease up sucks. house hunting has taken a front seat over this.
also i am abandoning the water to air intercoolers in the manifolds. the volume is to big and will make it lazy. (i need razor sharp throttle response for the paddle shift that im running.
also bonnet clearance is an issue. i want to raise the engine a cm or 2 for ground clearance. stock sump will be marginal at best,,
ive got some old hypertune s2000 plenum shells i am modding to fit. (shortening and mirror imaging one for the r/h bank)
the water to air coolers will be mounted in the inner guards out of the way.
all but finished my 110L fuel tank. all in 316L so it wont corrode. twin walbro 400's staged and an internal gated surge tank/pot
post-19586-0-09213900-1457252365_thumb.jpgpost-19586-0-20692500-1457252375_thumb.jpgpost-19586-0-53988000-1457252389_thumb.jpg
  • Like 1
  • 2 months later...
  • 6 months later...
  • 1 month later...
getting close. just finding the time has been hard + the 90 odd wires for the engine wiring harness took some time to make.
got the air shift piston and linkage sorted so i can use the stick and have paddle shift.
shouldn't get hot with the "super fan"
  • Like 6
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
