  • 5 months later...
  • Replies 296
So to bring the thread back to life, i sent the car down to speedfab.com.au in smithfield for some custom fabrication work.
The rear diffuser is about 80% complete with the transmission cooler mounted :
A billet peice was made to retain the factory jacking point
Diffuser air guide cutout for transmission cooler
Custom made hicas bar delete
Thats great!
Did they make up templates so they can fab up a few more of those diffusers?
I've been considering something like this to allow a second rear mount radiator to be run, so I can keep engine temps at 80 degrees regardless of how exuberant I might be driving...
Thats great!
yea they had templates but only rough ones. most of it was custom made as they went. but u can send them an email and they'll hook u up.
how much does it weigh compared to a factory carbon one?
it weighs about 2kg's heavier than the factory carbon one
Rob and Anthony do top work, had my car there when your car was there.
I had to stay for an extra 5 mins while Rob was moving your car outside, sounds mental as always ;)
your car was the white r33? if it is, it looks very clean.
Wow, that's incredibly impressive work.
This thread is never a dull read :thumbsup:
use to see this around my area all the time, it sounds even more angry in person lol
looking choice as anthony.
what did u do with the oem diffuser?
i'm putting it away in storage
looks sweet as
Will you be at powercruise coming up 3rd march ! ?
I hope you are again , this car MADE powercruise last year.
yes, i have a garage again this year
Was there reasoning behind why they didnt run the diffuser all the way to the side, rear spats that are beind the wheels. Amazing fabrication...some goods craftsman out there!
to use the factory mounting points
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
