its hard to see Dale cos its white and plain but once the bonnet is painted and glossy then it'll look really good.......
That is a sexy beast! Hmm bonnet upgrade one day maybe? Haha
Where did that bonnet come from? Modelled from a Dolphin or is it a Dolphin one?
yep its a freeway dolphin bonnet apparentely the first one thats popped up for sale in 4 years.
they dont make them anymore, so was lucky to pick it up second hand!!!
apparently when new they sold for $1600 but i'm hoping to make them for under $1200, going to speak to some mates but i'm thinking i need atleast 5-10 people who are keen to make it worth my while.
Any chance of a carbon one...?
couldnt be to hard LOL i'll sus it out aswell.
need to get corvettes secret in clear coating for that one LOL so it doesnt get UV damage!!!
  • 1 month later...
well after having a ball at Texi on Saturday my power steering is broken,
so its either I blew a pressure seal in the rack or the pump, its not leaking but it don't work.
at first I thought it was intermittent but now im pretty sure it doesn't work at all.
also a side note: maybe Alex would know, is the Series 1 and 2 power steering setups different seeing as the S2 came with a cooler? just wondering cos I would like to upgrade as I believe the S1 unit cant stand up to the abuse of full opposite lock drifting HAHA
I'm pretty sure the pump is the same, except a (piss small) cooler was added in one of the lines. It sits right at the front in front of the A/C condensor.
Your not running a P/S cooler? If not, get a small PWR cooler, and plumb it in the return line. I think several guys should be able to let you know their set ups. I think a seal in the pump unit is the first to go.
It's well known the pump will fail at the track without a cooler. Any small core will do, I am using a motorbike oil cooler but I have a spare small trans cooler here you could buy cheap if you want...
its called full lock drifting to much pressure/stress I would assume, I just wanted to know if the S2 pump or rack was different/better otherwise I will get mine rebuilt and modified so that this doesn't happen again if I decide to go drifting again.
like I said it wasn't leaking anywhere and I couldn't see it boiling in the reservoir and the cooler wasn't hot enough to burn my hand but that was after I felt it fail.
Did you use a spray can on the bonnet. Would look mad in 3m black or carbon vinyl wrap
yes I got the black off it and used a spray can so it wouldn't stand out as much to the police, but it'll be taken back off and finish being high filled and painted properly.
yeah it would look mad in black or carbon but I don't want it to stand out an pull unwanted attention :)
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
