For the not so good news, the brilliant bonnet struts i fitted have been working well but i use the bonnet quite a lot unlike the others i guess and it has created a weak point in the bonnet and it has now effectively collapsed... Its dissapointing as the bonnet was repainted and looked pretty good up until now -
I guess this was just a freak failure and i dont think there is anything wrong with the actual product.... They are a good price and worked well, maybe too much use :(
I wouldn't bother with the temps at the hillclimb. You're not going to get them warm enough to gather decent data, and by the time you make it back to the staging area, they are going to be cooled of any heat you did make. Did he show you how to take temps?
Nope there will be no temps taken at this event! No point and i dont have the gear as yet....
Yes he showed Carmen how to do it as she is in charge ;) Gotta get a proper pyrometer etc
Anyway, representing SAU at the Nulon Nationals means time for some Nulon oils -
Corporate-Logo-black-background_zpscc39a
Gearbox was a bit grubby as usual... Am going to have to mod the breathers before the next track day as both the gearbox and diff are pushing their love juices out all over the place :no:
Mat, that's generally an indicator that the gas struts are carrying too much pressure for their allocated task.
Bonnet struts don't need a great deal of pressure in them; otherwise they basically become a load point like yours have done.
This kind of damage is super common on Alloy, Fibreglass & Carbon Bonnets.
The Strut re-gas guys can set strut pressure to suit particular appilcation; this will prevent a repeat performance.
I've had hatch struts gassed at a higher pressure to allow for a rear wing before.
I think this guy will be the closest to you? They are mobile; so they come to you.
Strut Re-gas Hunter
Arie Oosterveen
Cnr Church & Foundry St
Wickam NSW 2293
Ph: 02 4961 3255
  • Like 1
Yeah that was my guess, good info mate!
Not sure if i can salvage the bonnet and just keep it for now until the car becomes more track based down the track! I want to keep the nice stock look if i can!
thanks for that. am going carbon bonnet soon and was going to use my current struts. you might have just saved me an expensive bonnet! thank you.
Bugger about the bonnet Mat, I sure hope the struts don't kill mine.
Will be interesting to see what you think of the Nulons too.
I have been using them for the whole time I've had the 33 and the 31 now is primarily Nulon filled too.
No complaints here, improvements more than anything. :D
This is your friendly reminder.
Pletty Prease.
Lol sonofabitch! I just saw this friendly reminder... The next event is at Wakefield and i assume you WILL be coming to watch ;) Then you can grab some while you are there...
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
