They are track rims. Track rims don't have hub caps.
Get a fkn grip,!!!!!!
All you will do is deposit them on the outside of corners when the wheels get hot.
I am trying to get a fkn grip hence why i have track rims :P for the fkn gripz!
Fridge? Where will the mattress go?
Giggity :)
:banana:
Show us some more pics of your trailer. :yes:
Car sure sounds angry, with traction questionable...
Haha will have to take more just for you :P
Traction was an issue, but maybe if the driver wasn't so much of a numpty that could be resolved. :whistling:
Softer foot would help... just sayin.
There is not some magical rubber that is going to hook up 390kw. You have to learn to pedal it. Off to school for you; Trackschool mo fo!
:laugh: yeah i know...
Nearly every event i have been too has involved teething issues so most of my focus has been on the car, its finally at a stage where i can start focussing on actually driving and enjoying it! And i plan to do plenty of that this year! Hurry up Friday :yes:
I took your driving approach at the motorkhana I did on the weekend and just did throttle on/off. Limiter all the way :P
Lol i saw some of the video :whistling:
While you take a piss, I'm going to fk with all your susp settings and pressures so you have the best chance of actually hooking it up.
But yes, Friday is the day you stop driving like a p plate V6 commodore driver...
I shall distract him lol
Lol fark off :P
If anyone gets a run in the passenger seat it will be Carmen, I am sure she will have plenty of good advice for me :blink:
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
