hahaha, yeah I agree totally with everything above! I'm not *too* concerned with how I look while I lose the definition, though let's look at this in an absolute worst-case-scenario deal - I won't be happy with the end result and wind up more or less back where I started. Call it an experiment or experience at worst really. I get big (and fatty), cut back and I'll either be happy or disappointed with it. I'm aiming for a weight, and when I reach it then I'll cut back while trying to hold onto as much of the muscle I've gained as I can. Once that's done, we'll see where I stand :)
Though I definitely don't like not having as defined abs now hahaha. It's like NOOOO WHERE YOU GO?! COME BACK :(
Go for it - Im looking to cut weight & then maintain, making slow gradual increases with lean muscle mass. No bulking up for me.
From age 19 to early 20's I worked out at a gym and put on over 30kg of mass to my 2m tall frame. 78kg 6'8" to 110kg over 3yrs, a couple years later was at 118kg with home gym sessions. Great size. Surgeries depleted my attitude and ended up at 132kg, drinking 3 bottles of bourbon weekly (to wash down the pain pills).
When I started my gym weight sessions 35 days ago I was 115kg, 15 sessions later Ive lost 2.5kg of mass but gained a bit of 'shape'. Hope to find a perfect zone at or under 110kg, gradually increasing muscle mass while decreasing body fat stores. Ive got my goals (physical & mental) & am working to achieve them, then maintain them ;)
Yep, I see what you mean.
Just gotta reiterate - my objective is to get to a weight, and then cut back. I don't intend to stick to a weight, I just wanna hit that marker before I drop the fat and then ideally maintain whatever I end up on.
ill give ya a tip... look in the mirror, not the scales, because they will fu$k with your head
haha yeah I do both, scales definitely f**k with my head though. f**king water weight etc fluctuating something crazy hahaha
haha no way in hell I'd ever post a 'before' shot... so embarrassed when I look at some old pics... really let myself go through the mid 20's lol... it happens quick too, one day your all fit looking and like I can eat/drink whatever I want... then BAM, where the f**k did this belly come from!
yeah weight can be deceptive... I weighed in heavy the other day (85kg, up nearly 2kgs) but spent the weekend down the coast and looked good in some pics the Mrs snapped so never 100% trust the scales
ah yea, derp. lol
well I just did a bit of a dodgy measurement now (using a ruler and standing against the wall, lol) and I came up to 172cm. Close enough
That's about right because I am 173 and I think we are the same height...
Haven't a clue lol. I know I've gained some for sure though
Buy me a set of skin fold calipers and I will do the test for you! aka I need to get some but can't be assed, hey it is my birthday soon after all.... lol
Chin up princess, it's OK!!! Mind you I weigh myself and Zane threatens to hide the scales... On the plus I've lose 3.2kg this year so far :thumbsup:
hahaha good shit Melly :P
I'm taking a week's break. Haven't had a break in a very long time, have felt like absolute shit for a week and a bit now. Something's killing my sleep, and I'm flat out not getting time to eat during work other than lunch :( really giving me the shits
Good to take a week off once in a while, if not for some major muscle recovery and routine change up, then to feel how sore you are the next day...makes you appreciate the level you were at prior to the break and how conditioned you were to it!
  • 1 month later...
Was actually thinking about that right now...been meaning to, but getting sick with tonsillitis the other week and having lost 2kg due top not eating had knocked me back a bit. I've recovered about 1kg of that weight so far, but my strength has dropped severely which it's pissing me off.
I'll see where I'm at this evening and give a proper update (with pix fo da laydeez) lol
Ok, weighed in at 76kg just now. I have done all my weigh-ins at the same time, so this is accurate when compared to previous.
Gotta say I'm pretty happy to be back where I was lol. Strength is slowly coming back, really need to work on my mental focus during sets though - seems I have a habit of just smashing out the first few reps with average form causing unnecessary fatigue, then the reps that count are seriously difficult. Worked on this shit for incline DB press and flat DB press this evening with good results.
Current work set weights for "push" day as follows:
Barbell military press behind head (standing) - 40kg
Dumbbell incline press - 28kg/hand
Dumbbell flat press - 36kg/hand
Dumbbell flies - 16kg/hand
Dips - 30kg weighted
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
