hahaha NO f**k that shit. What you can see a hint of on my ribs there is the name, date of birth, and date of death (if they've passed) for each of my 5 family dogs I've had through my life. Decorating the 5 lines of text is a bit of a generic/cliche rose bush/vine design that extends from the bottom line of text on my side, over my back, all the way up to my right shoulder. On my right shoulderblade I have another 2 lines of text, which are lines from a song.
Keep your shirt on for the next 6 months.
problem solved.
General idea lol. I'm gonna reduce calories by a little bit shortly since I really am over eating, but otherwise f**k it lol
Good progress dude.
What mutt have you got at the moment? Got a post up in the wasteland thread?
I've had 2 blue healers and 1 red healer (all passed), and currently we have another 2 blue healers. I haven't posted up any pics in that thread as I don't have any decent ones right now :( will have to harass my mum for some haha
  • 3 weeks later...
Shameless bump with some updates.
Lift progressions:
Bench press - 100kg 4 sets of 5 reps
Weighted dips - +50kg 4 sets of 8/7/6/5 reps
Incline DB press - 36kg 5 sets of 9/8/7/7/5 reps
Incline leg press - 380kg 1 set of 6 reps
I've started to get over the seefood bulk diet, there's not enough structure in the macros allowing for a little bit more fat gain than I'd really like...that, and I'm actually starting to bore myself of food hahaha. As a result, I've decided to cut back for a few weeks to regain some definition, then get back onto a MEASURED calorie surplus for a more steady gain for a while. Top pic is obviously one from before, second pic is one from this arvo after my first day of a harsh carb cut (compared to recent intake at least) as a reference for a starting point of this cut period. Top pic makes me look much more muscular and vascular thanks to the ludicrous amounts of carbs I was taking in haha...plus it was taken while getting changed in the gym (after back+bicep session).
Progress pic time....hate how taking a photo from waist height makes chest+shoulders look narrower than they really are :( oh well lol
hahaha cheers :D I can't wait til I can have my very first pic from the first post in this thread alongside my "final result" pic I'll be taking at the beginning of summer. Gonna blow my mind in the best way possible!
Even now I don't recognise myself rofl
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
