hahaha NO f**k that shit. What you can see a hint of on my ribs there is the name, date of birth, and date of death (if they've passed) for each of my 5 family dogs I've had through my life. Decorating the 5 lines of text is a bit of a generic/cliche rose bush/vine design that extends from the bottom line of text on my side, over my back, all the way up to my right shoulder. On my right shoulderblade I have another 2 lines of text, which are lines from a song.
Keep your shirt on for the next 6 months.
problem solved.
General idea lol. I'm gonna reduce calories by a little bit shortly since I really am over eating, but otherwise f**k it lol
Good progress dude.
What mutt have you got at the moment? Got a post up in the wasteland thread?
I've had 2 blue healers and 1 red healer (all passed), and currently we have another 2 blue healers. I haven't posted up any pics in that thread as I don't have any decent ones right now :( will have to harass my mum for some haha
  • 3 weeks later...
Shameless bump with some updates.
Lift progressions:
Bench press - 100kg 4 sets of 5 reps
Weighted dips - +50kg 4 sets of 8/7/6/5 reps
Incline DB press - 36kg 5 sets of 9/8/7/7/5 reps
Incline leg press - 380kg 1 set of 6 reps
I've started to get over the seefood bulk diet, there's not enough structure in the macros allowing for a little bit more fat gain than I'd really like...that, and I'm actually starting to bore myself of food hahaha. As a result, I've decided to cut back for a few weeks to regain some definition, then get back onto a MEASURED calorie surplus for a more steady gain for a while. Top pic is obviously one from before, second pic is one from this arvo after my first day of a harsh carb cut (compared to recent intake at least) as a reference for a starting point of this cut period. Top pic makes me look much more muscular and vascular thanks to the ludicrous amounts of carbs I was taking in haha...plus it was taken while getting changed in the gym (after back+bicep session).
Progress pic time....hate how taking a photo from waist height makes chest+shoulders look narrower than they really are :( oh well lol
hahaha cheers :D I can't wait til I can have my very first pic from the first post in this thread alongside my "final result" pic I'll be taking at the beginning of summer. Gonna blow my mind in the best way possible!
Even now I don't recognise myself rofl
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
