What I've always wanted to know is what are R34 and R33 GTR drivers talking about when they say their car has XXX RWKW? Surely they aren't taking the driveshaft out of the transfer case to get these readings, and to my knowledge only the 32's AWD can be disabled by pulling a fuse. Is there a way to disable AWD in a 33/34 GTR?
Yep. Pull the shaft.
Is it because they don't have an AWD dyno available? If I had an AWD car I'd prefer an AWKW figure.
Pretty much. Those tuners who do have an AWD dyno will use it to measure awkW.
  • 4 months later...
My R32 GTR with only an Exhaust after the catalact convertor did 203 kw at the rears, Evrything else was stock
that 206kw shit they talk about is bullshit ! the gtr is in another league comparing them to evo's and wrx's is quiet and insult to the makers..
hense
now with the R35 THEY MADE IT VERY CLEAR THEY DONT EVEN WANT TO COMPARE THE GTRs TO THESE CARs, BUT INSTEAD: PORSHE, FERRARI, LAMBO etc...
Edited by GTRAAH
And flywheel to wheels loss also comes with some controversy. Some claim about 25% loss from flywheel to wheels, but personally I guess it is mostly a fixed amount, not a simple%...otherwise a 1000kw car would be loosing 250kw in the drivetrain :teehee:
In rebuttal to this;
I've heard that autos are around the 15-20%
Manuals around 10-15%.
And I would think a percentage COULD be relevant.
The faster the motor turns, and gearbox and diff, the more oil will be squeezed through the oil pump, and squeezed from the gears.
It's like a boat through water, the liquid can't move out of the way as fast, and it requires more power/torque to displace.
This is my thoughts on the matter, unfortunately, I've never done or had the opportunity to do testing.
Would love to find out though.
Thanks for reading my rant.
hense
Cool Story!
Under the laws of physics energy can not be created or destroyed, it may only change state.
Therefore to lose 250kws you need it to become another form of energy other then kinetic... That normally means sound or heat...
While 1000kw cars may be noisy, they are not producing 250kw of noise... Nor are they boiling diff and gearbox oil or melting metal parts... Hence they can't be making 250rwkw in heat either...
They're not storing so no potential energy and I don't see them getting brighter, therefore they're not pitting it out in light energy...
Since there is no other energy forms available... They must be putting most of that power through in kinetic energy...
Most losses are caused from drag, primarily from bearings, which have a set coefficient of friction, meaning that it's primarily a constant loss, not a percentage loss.
Autos and manuals do "lose" different amounts of power purely from the design of the trans and torque converters/clutch. The main part of this is the torque converter, as it is designed to slip a kittle and use a liquid to transmit power, this means you end up losing power in the form of heat in this scenario, but only a bit.
The loss is a fixed amount, NOT a percentage.
Though more correct then the straight % loss this is also incorrect. There's certainly a lot of car forums quoting their theory's but little facts, it seems very hard to point to real facts without going through the science which would send most car forum people to sleep. Duncan first post probably was as close as simple reality can get.
I refer to a Wheels magazine comparison of quoted KW and tested RWKW, between high output falcons and commo's. There was common theme of 40-50kw loss between 240-310kw, lower loss for the less powerful in general.
So if we say 40-50kw is a fixed amount, what happens to cars that output less then 40kw, there has been a few in years gone by. Do they not move?
In reality the formula would be closer to a parabolic equation with a high % for low power cars and getting less % for high powered cars. Certainly different cars have different power loss due to differing designs and maintenance. 300rwkw approximatly equals 350fwkw.
Again you can't tell some people, most in the ford forums still quote the old 30% that went out years ago. Sure my 300rwkw car has 400fwkw??? sure....
I think that is that case as well. i don't think it follows a set % or a fixed number.
My 2 cents,
Owning a R33 Vspec and having 500+ runs on the Advan Performance 4wd dyno under my belt, we have noticed a few things.
1. Peter will only tune the GTR in RWD due to the attessa interfering with the amount of 4 wheel power delivery ( almost every run it's slightly different based on how the attessa feels at the time).
2. Based on the same tractive effort, the 4wd kw figure seems to vary by about 5-10kw on almost every run. This is also spaced days apart on the same tune so heat soak is not a factor here. The RWD figure on the same tune remained within 2-3kw every run.
3. My GTR's 4wd mode generally saps about 15kw from my peak power figure (within the variable bracket I stated at item 2.) It's simple physics as was said before, there is always going to be some power loss to the treads and more so when the engine is trying to drive 2 drive shafts and 4 axles instead of 1 shaft and 2 axles.
IMHO it's not the peak power you make in these things that's important, it's all about the torque you can produce to keep the 4wd system accelerating right up through the rev range which makes all the difference...
Fun too :-)
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
