Soooooo, filled up today. With normal driving (I mean squirt here, squirt there) on E85 I have reached a pretty low 14.6l/100. My lowest was all freeway on 11l/100.
And I thought I'd crack it the SLR today, then the sun decided to run away. Oh well. Still quite purple without direct sunlight.
d4abc1e5-09e7-4890-9fb3-e6223c323ed2_zps
9fd66eb2-2c38-4597-8e56-0c2a7c0679a8_zps
2507370c-59fe-4eb2-9752-fcc18f15a7a0_zps
8ae382d9-e1d2-4df0-a44e-d1faea4b3f9b_zps
  • Like 5
Collonite will have to wait. Melbourne weather is shit today so I just read your whole build thread instead. I like the way you've gone about everything. Kept it simple and effective. None of this ott bullshit. You've gone as far as the cars purpose requires. Well done. That paint is immaculate. You are one lucky prick. Factory paint ftw.
Found some more photos.
The car you see rolling through the dirt was a ute with 20's that lost control at the end of the straight at Wakefield.
Heed these words, DON'T go to the track on 20's.
1524686_10202510487113573_1995185959_n_z
1528719_10202510485513533_846587639_n_zp
1499555_10202510489193625_895478773_n_zp
1779798_366206733520301_779223747_n_zpsc
1904018_366202670187374_1106108262_n_zps
1526319_343445902463051_2133847098_n_zps
Currently I am in negotiation with Federal Tyres because their shitty RSR's have started to split on 2 of the tyres. (common issue, was hoping it wouldn't happen to me). So now Im getting RS3's. Fingers crossed for some compensation haha.
1BD52F7A-3D72-4A88-B161-EFBE0490561A_zps
  • Like 2
I had the same issue with my rsrs. Federal usually tell people that they are OK to run like that and will only replace if the de laminate. Wtf. I know of others that have run them like that and reported that as they wore down the cracks wore away. I ended up selling mine off. Let us know what federal says and does.
  • Like 1
Time to try some of this stuff. It gets a good rap from the guys over on the detail forums. Meant to last a few months aswell.
Ordered some of this today. So cut and polish 1st then apply this?
Hmmm. If I peel it back there at the biggest tear I can just about see the cording on the tyre.
I wonder what they will say.
Doesn't sound too good. Will definitely be interesting to hear what they say. They've recently released a newer version called rsrr. I wonder if the problem has been fixed with those.
@Robzilla32
Ideally what you want to do is clay then polish then wax. But you will be able to get away with a polish then apply the wax. Take note of my tip before.
(Don't you all go buy to much of this, I don't want them to bump the price up like mcquiars or some other stupid expensive brand :P)
@admS15
I wouldn't risk it hence moving away from federal. But let's see how it all goes. I'll be doing a skid pan on them so if they let go that will probably be the time haha.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
