Are you planning on doing any work on the auto box to strengthen it up a bit before putting the turbo on, or just gonna see what happens?
Nice car too, it was looking really good on the 15th Anniversary cruise.
Thanks Mate, good efforts on making it from Bathusrt too!
My plans for the box is basically the transgo kit, and a transcooler with Thermostat. On the Transgo site, it says that the kit for this box is designed with turbo/super charging in mind. So with those two things in the box, I'm hoping it will cope. From what I have read, its mostly about keeping the temp down, as to not fry the box. Generally I don't drive it like I stole it, so if it survives the tune (which I will tell them about the box, and to be mindful of it) I'm pretty sure it'll go fine on the road.
Will that have any effect apart from speeding up the shifts? I was thinking more in terms of protecting the gearbox from any problems caused by the increased power levels, if that is even going to be an issue.
I thought that's what shif kits do??? :blink: to prevent "flaring and destructive gear changes" as per Jetwreck's words...
fkn LOL @ Dale.
Also LOL with Dale :)
Very interested to see the sump mod Alex
Is that cause you might be pinching one...? Sump has been cut to clear all various extra bits and pieces. It's going to be welded up monday. I'll get photos when done.
Lol Dale- its a build thread, not just a look at my POOOOWWWWWWWWERRRRRRRRRRR thread thumbsup.gif
Plus, someone said we have to fix a big black pile of backfarting parts first before getting carried away...tongue.gif
I'll get some photos of the kit up first. That'll shit Dale some more...
Take your time & do it right; I'll stop filling your thread with junk now.
Watching with interest as this develops; it's going to be a very interesting package, with performance to match the looks.thumbsup.gif
Carry on.
good to see my hks turbo kit is going to good use. funny thing is now i want a m35.....lol
Do it, Dave!
BTW, is that John's new engine I've been hearing the past few nights over here? Fck me, it's loud, but it also sounds good!
Well, I got the sump back on friday arvo. Got modified to clear the front diff, and the stock oil cooler piping. This is what it ended up looking like.6275907256_845b266094.jpg
The hole on the rhs is for the oil return. When I got it the wings were the same size on both sides. The screen door in the top of the sump seems to act like a baffle.
Edited by PN-Mad
1319442563[/url]' post='6077090']
Custom modded HKS sump, noice. When are the goodies going on?
Well, now I have everything I want. So, we want to sort out Craig's car before another ends up in bits all over the place. Hopefully within the next month or so. Wish you were in Sydney, I'd be getting you to make up a exhaust.tongue.gif
1319442918[/url]' post='6077105']
Nice Alex. Very nicely done.
Lose about 200ml of oil I guess? (not that it will matter)
yeah, probably lost a bees dick worth of oil. Not much to worry about.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
