11.5:1 comp is for the people who build hardcore turbo racing engines, run it like porsche did in the 70's.
really want to see this whole thing pieced together and some numbers :D
good luck with everything
So do I mate, So do I!!!
Well, thought I'd getter get some pics of what we're playing with before it goes in.
First, the turbo itself- HKS/Garrett GT3037 S 56 / 1.12 Ext gate.
An Intercooler-
Metric ass load of bolts screws, clamps, banjos and washers.... that'll be fun in japanese...
Got Gate? Yup a HKS GT II 60mm
Cast manifolds from a VQ25det we presume
Going to an exhaust with a HKS metal Cat
complete with 4 holes for the sensors
Another metric ass load of piping- exhaust/intake/intercooler
Pod filter- lol... shinnnyyist packing in the whole lot!
Other supporting bits - A Walbro, and deatschwerks 600cc drop in injectors.
PWR tranny cooler, no photo, and a little Blitz Boost Gauge.
Had the car on the dyno at the tuners today- needless to say its interesting what different numbers dynos spit out. Lets just say, I now want that turbo on!
Edited by PN-Mad
Is the second inlet off to the side there for the wastegate piping?
What 4? EGT, O2, wideband and...?
Also what engine management are you going to run when this is done? I remember you looking at some kind of 350Z style flash, is that the final option?
Should be awesome when it's done. Looks like everything is top quality in the kit!
~120awkw?
Picture does not to that HKS cat justice IMO
A bit more - 131awkw. Funny when I had it stock on another dyno at 147. I know, I really shouldn't pay attention - dynos are only comparative tools. One can be completely different to another, even if it is the same brand.
Pics of HKS cat for Cam...
Yep, thats where the Gate joins in.
Two each bank- before and after the cat sI think...
It will be reflashed. Had the ECU out and to the Tuner, confirmed its the same as 350Z/R35. Prob the easiest way- avoid piggybacks etc. Haltech looked like a nightmare - their words not mine.
hmmm, wonder what would be easier, or even, more cost effective in the long run, buy another vq35 engine and rebuild that with pistons, gasket etc etc. then throw it into the car and sell your old engine.
that would mean less fart assing around and easier build up, plus no need to keep your car off the road. also when your done you can sell your engine for roughly the same as what you paid for the 2nd engine.
the downside of that is, you need money for the other engine, not like where its a rb25 which you can pick up for a couple o' beers.
the other upside is it wont be a ticking time bomb when your running your 6psi on stock engine and compression.
but all is a money issue.
ps. ill buy your turbo for a hi 5 :P :P
Yeah, its not a bad idea. At this stage(a) I don't want to go down the build path financially. There are plenty of VQ35's running around with a lot more boost than what I would consider safe. Have a peek at G35driver.com if interested. There are cars there running 10psi, with near 50k miles boosted. I'm quite conservative regarding my ambitions. What has been made clear to me is that its all up to the tuner. Shit tune, and someone who isn't carful about how they tune cars- then some of them don't even make it off the dyno. On the other hand, if you know what your doing, have teh right supporting mods, and tune it to the strengths of the motor- some people have over 500hp from the stock bottom end.
Oh, and using my turbo, if you were to give me a hi five, you might start to make boost by 5000rpmtongue.gif its got a rather large rear on it!!
its not difficult to drop the motor out of these cars to work on them. i rekon it would take a day and a night to do it all
Edited by PN-Mad
dont worry, i like a big rear, pref in conjunction with TT's ;) dont mind what rpm she makes me smile
haha
Firstly, lots of shiny stuff looks nice...
Secondly, extra O2 sensors for each bank of cylinders I get. But why are the holes all on the one pipe? Shouldn't there be 2 pipes with 2 sensor holes each or does that pipe come apart?
Can't wait to see it all go together, good luck.
1320755690[/url]' post='6101072']
Single turbo set up Leon. So it. Will be very similar to a vq25det set up in the end.
Alex, are the o2 sensor holes on the bottom of the pipe? I know the widebands are meant to be fitted so that the sensor can drain moisture.
Are the pin outs the same as the 350z ECU by any chance Alex?
If unknown, would you mind asking your tuner for me?
Oh, and we will be installing my mates kit the weekend of the 19th Nov but we won't be dropping the motor so should be fun
Found out today that NM35 cat back bolt up perfectly to my car!
Got one of these-
Autosol metal polish. holy shiz that stuff is good. The exhaust wasn't in great nick when I got it, it is second hand. But being stainless no rust. Polished it up with some autosol, and it just gleams.
Sounds seriously mean too. I'll get a vid soon.
Edited by PN-Mad
lol, niiice. sounds mean.
i say we should have a "sound off" thread, where everybody posts their stats and mods, and then the soundclip to it, that would be pretty mean :D
....... i will start one later on tonight when i can get a cameraman for my car.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
