Will you be working at "The House of Stagea" tomorow? Might see if I can nip down for a perve...:whistling:
yup....he will be there...I have a couple of small projects on the run I want to finish and I'm sure his Aric wants to bolt all his bits back on.
Fairy Muff... I'll give you a bell tomorrow.:thumbsup:
Its a great idea Dale, but there is stuff all room there. I'm running about 4 or 5 hoses in the area already.
What I really need to know is does it matter being before or after the AFM?
Ideally you want the BOV as close to the throttle body as possible and certainly between the afm and the throttle body.
The pulses reversing through the AFM would almost certainly cause issues.
1327738925[/url]' post='6207971']
Yeah, that's the conventional thinking. Thing is, I has no bov now, and it doesn't seem to suffer any ill effects other than the comp surge. Nil afm issues. The afm will only read in one direction.
That's why I'm a bit puzzled.
because your afm is in the cooler pipe you can actually have an atmo bov if you wanted to, so long as its on the pressureised side of the Turbo (duh) and pre afm
At this position the afm hasn't metered the air yet so loosing it to atmo doesn't matter
You could also put a recirc bov here, or after the afm, but a recirc bov is probably best after the afm to prevent reversion and air going backwards through the afm on closed throttle
So was there a question about where to locate it or are you happy with how the car runs? The reason you want it close the throttle is to release the pressure as early as possible to shorten the pressure wave. There are lots of cars that have the BOV located somewhere further away and it works but it is not ideal. Conventional thinking is there for a reason.
Last I checked pulses of air moving across the afm element, changes the afm voltage regardless of direction.
Conventional thinking doesn't have the AFM 300mm from the TB and the intake about 1800mm from that. The afm is not designed to pick up air travelling in the opposite direction, it would be very much shielded from the path of the air reversed, thats what I figure when I look at the thing. At the moment I can't say there is any ill effects in driveability because of the air backing up, just the comp flutter, which is actually a little milder that what I initially thought.
If it was going to be easy, I'd put it before the AFM, problem is I have very little space there anymore.
Scotty, I do care about the noise. In Sydney run a external BOV and your classed as full hektic- bend over and get ready for the po po.... Funny thing is with the flutter, they would think its a BOV anyway.
Edited by PN-Mad
Cam, Below is what I had to do to the Fnt bar. nothing drastic - just one cl ip to go, and a bit of sanding to clear the top cooler pipe.
All done!
I'll get some underneath pics, just have to get it up the ramps!
Looks really neat Alex. Well done to all involved thus far.
What does HKS suggest re BOV, if anything? Surely they gave detailed engineering info, like how they acheived their design criteria for a truly bolt-on/no mods necessary kit such as yours, lol.
And you don't strike me as the fully hektic type that goes around looking for trouble. I'm sure there's a solution somewhere...
Thanks Alex. I was wondering how far the grill came back to the intercooler recently actually.
Oh, and nice little shroud/box for the pod, any point to the stock air funnel now though? are you going to route air from it to the pod?
No point really to the duct. Its not in there now. The pod gets heaps of fresh air from below, through the grill, and up near the wheel arch.
Craig has taken to writing HKS on various things on my car now. I have to say the bracket he made up for the trans cooler is a work of art.
Edited by PN-Mad
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
