just bought a exhaust for my bike, $125 delivered from the US haha.. gonna be loud as f**k
same as in this vid, gotta skip to 1:00 for it to be on, got cut off today by some bitch in a SUV hopefully they hear me coming next time..
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
