Lol game over. I woulda pulled over and try to kill the f**ka.
If i couldn't find it then well it would be one paraniod drive on the way home....
Pulled over still half on the road and jumped the f**k out. Lost it for a while then found it on the back of the steering wheel. It ran a few laps while I tried to kill it with my boot, lost it again then eventually found it dying on my seat.
Woulda left the car there and reported it stolen if I couldn't find/kill it
orrite, bringing the "fail whale" kakimoto widebody for SAUNats... maybe. Gotta get a permit to drive it cos the trade plates are on compliance cars.
first time i saw that thing was happy cup meet in 07 or 06 at the first meet i had organised. was a nice surprise to say the least.
hmmm looks tlike the quarters are different, or could be the shadow?
def running spacers. those guards are rolled and pumped like a mofo.
this one time, i was driving home at night and i felt a tickle on my neck....ignored it.....tickle moved to my face. looked in the rear view, calmly pulled over like a boss, slowly got out of the car an FREAKED. huntsman on face.
driving with my arm hanging out the window something similar somehow landed on it while doing 80. luckily it fell off after a couple retarded spec arm shakes
Should have given that sucker a few right hands to the mouth.
Pic again?
cbf, wait till friday
damn straight. work hooks me up with qantas club and business class.
So coming up on Friday night?
yeah leaving friday at 4pm from melb. should be there by 7?
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
