May be in if someone can pick me up. Not comfortable driving my car around after the slidey dilemnas on the freeway
Only read to this far, unless you've found a lift already I can pick ya up kunt.
Grad accountant who I extended the probation period for has spent 1/2 and hour trying to open a file but couldn't and is asking me why.
All she need to do was to unzip and extract the file
Say to her.... unzip THIS
They don't teach how to unzip files anymore?
And regretting extending her probation now?
Unzip this and extract semen? Will try next time
Training session is this month for her. So will see if there is an improvement.
20 years doesn't mean 20 years to develop a more powerful engine, there's more to it than that. Any manufacturer, even Daihatsu could put a 220kw N/A 2 litre engine in the thing if they really wanted to, but it means more money on production costs and less fuel efficiency. But try passing in the RB20DET under today's emission standards and you would be laughed at!
And for that matter, 20 years prior to the R32 GTS-T was the TA22 GT which weighed in at around 900kg and made 93kw from a 1.6 litre N/A engine...
I think you'll find this car to be positioned with similar performance to other sports cars within similar price ranges. They may also be making space for more powerful versions of the engine down the track, giving marketing something to keep pushing the product.
I was hoping to buy one as a daily but it doesnt seem worth the effort :(
I'll keep saving up for the BMW 1M :domokun:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
