In November 2010, The Weekend Australian reported that "Treasury officials preparing the so-called Red Book of briefs for the incoming government were as divided as private sector economists about the strength of the property market."
In December 2010, an MLC investments strategist observed that "residential property looks absolutely obscenely overvalued and seems to offer very, very poor investment prospects."
In March 2011, Morgan Stanley global strategist Gerard Minack said that "we've had 20 years where the Australian consumers have been willing to borrow more to buy an asset that they believe always goes up in value. The classic sign of an asset bubble." and that "home prices are 30 to 40 per cent above fair value."
In October 2009, it appeared that the pricing of homes was being inflated by actions taken in October 2008 aimed at addressing the fallout from the GFC. Housing was identified as an asset class worth shoring up against the type of deleveraging seen in the stockmarket.
The government increased assistance given to first home buyers as part of its 'Economic Stimulus Strategy',. A substantial reduction of RBA interest rates also played a part in maintaining prices
2010: November - The RBA raises interest rates 0.25% to 4.75% citing the "economy is now subject to a large expansionary shock from the high terms of trade"
2011: February - New housing loans approved by Australian banks fall 5.6 per cent to a 10-year low in February.
2011: March - Prosper Australia launches a campaign for a "buyer's strike" in an effort to drive down prices.
2011: April - Melbourne median home price falls by $36000 (6%) to A$565,000 in March Quarter.
2011: May - The number of properties for sale in Melbourne double.
2011: June - Number of home loans in arrears 90 days overdue, rises to 15 year high.
The only sheep are the ones who keep regurgitating the same theories.
Whats your point?
If house prices are dropping, that means the people who were on the border of buying a property now can = Win
If house prices are dropping because people cant afford to buy, that means more demand on rental properties which means larger return on investment properties. = Win
So cheap house prices & increased rental demand sounds like good times to me, but you sheep can keep spreading your theories on doom and gloom.
So what is your point exactly instead of regurgitating stats/theories which have no key message behind it.
Ey dawg ey... there's a shit storm heading our way, best prepare your angus otherwise you're going to get ur angus swept awayh in all this blizzard babeaa. I've seen the effects of a busted asset bubble, it's quite catestrophic brah. People be sleeping in the streets and sheet....
Brb, gfc 2 heading your way
Just saw a massive stack on the Monash Fwy inbound just before the Berwick-Cranbourne Rd overpass. Car had clearly flipped, cops blocked off whole Fwy. Couldn't even tell what car it was. How the heck do you flip a car on a freeway anyway, would have to do some massive moves.
The back up of traffic is incredible! I'm glad I'm heading the opposite way.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
