Sau Friday? What's on is that one of those members cruises, didn't renew membership 1 cruise a year and paying $50 for the privelge couldn't justify it
It's not a SAU Members Cruise, MUZT3K started it, just a regular meet up / cruise.
Gentlemen, I can proudly announce...
...after owning several of you with pleasure, especially Alex
... Spittin out words like a Llama in this very forum (sorry Ric lol)
I'LL BE BACK after a long hiatus to KICK SOME MORE ASS!!!!!!!!!!!!!!!!!1111111!!!one!!!eleven!!!!one
Work is getting crazy so ill be back after my Miami trip in Feb ;)
Edited by Flynnn
Client has been on average $800,000 for the last 5 years.
Has no house, hardly any assets with hundreds of thousands of dollars in liabilities.
About to assist in filing for insolvency.
Life's hard being rich.
Happens a lot I reckon. Income rich, asset poor! Or....cocaine...
