Morning Nicole.
Tony, was awake during te procedure, only 2 were removed at this stage, my dentist were kind enough to give me 3 days sickie.
Local anesthetic were used, he said he won't do 4 at once cos of probability of swollen lip and cheeks or something.
Had shitty sleep for last 2 days and my brother is bothering me right now when we stop at a red light...
Morning Nicole.
Wisdom teeth?! :(
Went to autobarn intending to spend 50 bux. Walk out with 200 bux worth of shit. Ffffuuu
And it's still an N/A
:laugh:
Bought a turbo key ring. 40psi boost
Awesome bro!
Take to Race Pace for install and tune.
Tell me where the meet is I'll come
FYI
Just a quick email to remind you about the Hardtuned.net Xmas Charity Car Cruise we have organised for this weekend in Melbourne!
We are expecting a decent turnout of Import & Euro Cars, and have a great cruise route planned out.
Time & Date : This Sunday! 18th December 10:30am Under the Bolte Bridge.
What to Bring : - Yourself, Gold Coin Donation, City Link Day Pass, Packed Lunch or your own BBQ supplies
What the day will consist of :- Central Meet (10:30am) - Cruise (11:30am) - Lunch - optional cruise afterwards
Donations :- All Donations will be going to the Salvation Army, i will be going around with a bucket to get everyones donations on the day.
Map & More Info here:
http://www.hardtuned.net/forums/index.php?showtopic=513323
As with all Hardtuned Cruises - This is a great day to enjoy your car, it is a cruise not a race : Hooning & Dumb Behaviour is not tolerated!
FYI stay away from the Kinglake/Toolangi & GOR area's - ANY time of night/day.
There is a big Police Operation going on over the next 2 months, all hours of the day/night.
Main aim is to catch the late-night runs though I've been informed ;)
You've been warned.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
