Morning Nicole.
Tony, was awake during te procedure, only 2 were removed at this stage, my dentist were kind enough to give me 3 days sickie.
Local anesthetic were used, he said he won't do 4 at once cos of probability of swollen lip and cheeks or something.
Had shitty sleep for last 2 days and my brother is bothering me right now when we stop at a red light...
Morning Nicole.
Wisdom teeth?! :(
Went to autobarn intending to spend 50 bux. Walk out with 200 bux worth of shit. Ffffuuu
And it's still an N/A
:laugh:
Bought a turbo key ring. 40psi boost
Awesome bro!
Take to Race Pace for install and tune.
Tell me where the meet is I'll come
FYI
Just a quick email to remind you about the Hardtuned.net Xmas Charity Car Cruise we have organised for this weekend in Melbourne!
We are expecting a decent turnout of Import & Euro Cars, and have a great cruise route planned out.
Time & Date : This Sunday! 18th December 10:30am Under the Bolte Bridge.
What to Bring : - Yourself, Gold Coin Donation, City Link Day Pass, Packed Lunch or your own BBQ supplies
What the day will consist of :- Central Meet (10:30am) - Cruise (11:30am) - Lunch - optional cruise afterwards
Donations :- All Donations will be going to the Salvation Army, i will be going around with a bucket to get everyones donations on the day.
Map & More Info here:
http://www.hardtuned.net/forums/index.php?showtopic=513323
As with all Hardtuned Cruises - This is a great day to enjoy your car, it is a cruise not a race : Hooning & Dumb Behaviour is not tolerated!
FYI stay away from the Kinglake/Toolangi & GOR area's - ANY time of night/day.
There is a big Police Operation going on over the next 2 months, all hours of the day/night.
Main aim is to catch the late-night runs though I've been informed ;)
You've been warned.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
