Actually I like the blue one... how's the car going anyway? Quicker than your mates xr8?
Loving it so far, its a bit quicker, not much in it though power levels are about the same until I get a tune :banana:
But yeh my GTR was quicker than my new car at this stage - want that tune badly! Still much nicer to cruise to work in :thumbsup:
Is it that guy that cut his fingers off at work a few years ago? Ron or something?
yeah it's Rons' car.
Was rebuilt a couple years ago. Barely drives it and hasnt done any mods after the rebuild. Still running standard boost i think.
Selling cause he wants to buy a place :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
