Interesting! :)
Ash, Detour is BBNT, just under a different name. Same products. Om nom nom!
:O
:O
:O
I didn't know, never really go into Richmond. The one on Fitzroy st closed, so i just assumed they all died
Yeah the franchise itself shut down. I assume this one was independently owned and all the drunks from the Swan etc keep it in business. :thumbsup:
SIF the ones on Fitzroy St didn't though, it was always packed even @ 3am!
Must have been stupid owners to screw up that chain, was onto a good thing
looking to spend like 20K mate
this is what i was interested in and really liked how it had full car history
http://www.carsales.com.au/private/details/nissan-skyline-1996-11119075?silo=Stock&cr=&eapi=2&vertical=Car
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
