ahah :P i can understand that!
she can buy it if she wants! its for sale!
Told her about the sale bit... Don't think she wants a car that can break her hips!
Picked up new turbo...and so begins my quest for teh power and teh E-flex. Question...install myself or pay OTR $250 to do it? Seems like an easy job but I always run into trouble and woudn't mind playing COD while someone else sweats over my engine bay.
If I'm gonna settle for something in the middle I'd just go back to the 250 ninja and learn on that, upgrade to gixxer after 6-9 months
I've sat on my mates 250 Ninja, more upright position like yours than the real deal Ninja and other supersports..
There's a nice Ninja at my work every now and then, green which isn't my style but a tough looking bike..
I'm leaning towards an all black 2009 gixxer though, not a fan of the newer gixxers, something about the front just doesn't do it for me...
Just man up and get the gixxer, I kinda wish I did now but still happy with my bike. As long as you survive first few months should be fine.
Get the manifold taken off, and change the studs whilst it's being done.
Will cost more, but likely you already have at least one crook stud in there :D
Yep good advice this, I already have new studs and genuine gaskets ready to go on at the same time. One of the nuts already free spins from memory :(
Enjoy getting any broken ones out. I had 8 in total broken. Gotten 7 of them (one is being a tight as f**k c***)
Tried drilling pilot, them 5mm drill to left hand thread drill piece (easy out)
They all came out like that (easy)
This one won't really budge. Used shitloads of rust of ice, tried hitting it with oxy. No luck. :rant:
Keen to just throw it together with the one not on. (did it on old motor for same reason and lasted 3,000km (till motor blew) but thats not good enough. Want to do it properly.
There is my rant anyhow.
I'm full of it :D
And ye - Thread Doctor - he is a "come to you" guy, does it on the spot.
Cheap as well which is awesome considering how much of a headfcuk of a job it is to do if you dont have the tools.
Even most workshops just call him lol
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Likelihood of getting pulled over though? (When not riding like a Flynn)
You will get done for riding on a large bike while on your restrictions if:
1. By chance you are pulled over for a check perhaps for something else and they realise
2. They drive behind you, check the rego and note that the registered owner is not licensed to ride the bike. This can be avoided by getting someone else to register the bike in their name if you can convince them
3. You crash the bike. Insurance won't pay out if you're not licensed and I count that as 'doing yourself'
I've know multiple people who have been caught while riding on their restrictions or who have written off bikes while on them
i see.
put fake rego plates on and do a runner if you get pulled over :whistling:
but you'll most likely crash it since your still learning on it...
Lol exactly, I found the time on my 250 was priceless... Although I think I was a special case. Getting your knee down on the Black Spur on a 250 that is the sloppiest bike in the world isn't what most learners will be doing.
I'd recommend just dealing with a less powerful bike for max 15 months. It will do great things for your skills and you don't have to look over your shoulder. Once you're off them it's like it never happened.
can't you weld a nut on it and go from there ? then again if easy out didn't work i don't think anything will
Havn't done much welding and the studs 'tend' to snap approx 2 threads INTO the head so I don't know how u would go welding onto them with minimal space and surface area.
Ended up getting the last one so all good. :banana:
Edited by bluey33
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
