ahah :P i can understand that!
she can buy it if she wants! its for sale!
Told her about the sale bit... Don't think she wants a car that can break her hips!
Picked up new turbo...and so begins my quest for teh power and teh E-flex. Question...install myself or pay OTR $250 to do it? Seems like an easy job but I always run into trouble and woudn't mind playing COD while someone else sweats over my engine bay.
If I'm gonna settle for something in the middle I'd just go back to the 250 ninja and learn on that, upgrade to gixxer after 6-9 months
I've sat on my mates 250 Ninja, more upright position like yours than the real deal Ninja and other supersports..
There's a nice Ninja at my work every now and then, green which isn't my style but a tough looking bike..
I'm leaning towards an all black 2009 gixxer though, not a fan of the newer gixxers, something about the front just doesn't do it for me...
Just man up and get the gixxer, I kinda wish I did now but still happy with my bike. As long as you survive first few months should be fine.
Get the manifold taken off, and change the studs whilst it's being done.
Will cost more, but likely you already have at least one crook stud in there :D
Yep good advice this, I already have new studs and genuine gaskets ready to go on at the same time. One of the nuts already free spins from memory :(
Enjoy getting any broken ones out. I had 8 in total broken. Gotten 7 of them (one is being a tight as f**k c***)
Tried drilling pilot, them 5mm drill to left hand thread drill piece (easy out)
They all came out like that (easy)
This one won't really budge. Used shitloads of rust of ice, tried hitting it with oxy. No luck. :rant:
Keen to just throw it together with the one not on. (did it on old motor for same reason and lasted 3,000km (till motor blew) but thats not good enough. Want to do it properly.
There is my rant anyhow.
I'm full of it :D
And ye - Thread Doctor - he is a "come to you" guy, does it on the spot.
Cheap as well which is awesome considering how much of a headfcuk of a job it is to do if you dont have the tools.
Even most workshops just call him lol
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Likelihood of getting pulled over though? (When not riding like a Flynn)
You will get done for riding on a large bike while on your restrictions if:
1. By chance you are pulled over for a check perhaps for something else and they realise
2. They drive behind you, check the rego and note that the registered owner is not licensed to ride the bike. This can be avoided by getting someone else to register the bike in their name if you can convince them
3. You crash the bike. Insurance won't pay out if you're not licensed and I count that as 'doing yourself'
I've know multiple people who have been caught while riding on their restrictions or who have written off bikes while on them
i see.
put fake rego plates on and do a runner if you get pulled over :whistling:
but you'll most likely crash it since your still learning on it...
Lol exactly, I found the time on my 250 was priceless... Although I think I was a special case. Getting your knee down on the Black Spur on a 250 that is the sloppiest bike in the world isn't what most learners will be doing.
I'd recommend just dealing with a less powerful bike for max 15 months. It will do great things for your skills and you don't have to look over your shoulder. Once you're off them it's like it never happened.
can't you weld a nut on it and go from there ? then again if easy out didn't work i don't think anything will
Havn't done much welding and the studs 'tend' to snap approx 2 threads INTO the head so I don't know how u would go welding onto them with minimal space and surface area.
Ended up getting the last one so all good. :banana:
Edited by bluey33
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
