I agree Dez
People who actually believe that shit.
I say go commit a crime, use that argument.
Let me know when the court date is so I can come for the lulz
lol would be f**kin awesome to watch some cunt get locked up for some bad shit coz he thought he could pull this..
That Josh guy is a classic...even IF this bullshit was true, I guarantee the cop wouldn't have a f**king clue about it and there is no way in hell he'd drive away from being pulled over at 160km/h
Bunch of shit fallers and despos on there some ugly chick posts up some random shot 1000 comments later they still trying to get there end off.. Few of us took the piss out of the loser the other night for trololols
tell him to show you where it says that a return flow front mount is illegal (as long as you don't have a pod)
failing that, call him a cocksucker
One intake modification is allowed, you can have Reverse-flow FMIC assuming you still have standard airbox.
Failing that, do what Dezz said.
yeah i have only the blitz return flow/reverse flow fmic.. and i chose that one due to it being legal.
i am running standard airbox also..
coilovers i have tein monoflex and cant put standard ones back in because the rears were both gone within the first few months after buying the car..
so i guess ill either be telling him he is a 'cocksucker' or ill talk my way through a rwc
Ahahgahahahahhahahahah
Ohhhhhh alexxxxx <3 no homo
It's true though, about the FB stuff at least. It seriously hurts my eyes, and brain. Least it keeps it off the forums, means less work for me.
Mmm will depend if im catching up with a lady or not.
However unlikely regardless I think... Mt Baw Baw sprint is on the w/e after. Really cannot afford to put that in jeapordy as it's going to be farken nuts!
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
