Yeahhhhh
maybe not
current engine
oh and that a newer injected 302 not the original carby 289
That's all?
Why do gay ppl have a march? I mean they don't have a straight march..
They need help marching straight.
cos lesbians...nuff said
That's all?
oh yeah. that was a motor out of a ef falcon with extracts zorst and a a panel filter.
sad eh, but still more than the original 289
351 Cleveland Martin.... do it
um have you looked at a 66 stang bay.
clevo will not fit, end of story.
has to be a windsor, looked at a stroker and will prob do later just want to get back on road atm.
but will never be a monster HP car.
so big plan give the stang to the missus as a cruiser and build a 70 cuda with a hemi.... but that 10-15 years out
Here I was complaining about stock R33 GTR not powerful enough...
ya exactly one week after I bought it..
hell what does every 21 year old do with a V8???
lucky for me my folks live in country so we had our own paved road.
Haha, that's awesome.
that is if there is a dyno day next year.
with the lack of cars going on the dyno makes it hard to ask workshops to open up for the day to us.
think there 22 in total and some of those were cars chasers called up to make up some numbers.
excellent turn out and good social day but not a huge amount on the dyno.
Have always been big turn outs at recustoms dyno days!
West-melb was too far to make an effort :(
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
