And on top of that, I know Of the perfect hks 2535 setup for sale, with manifold, ex gate, and stock heatshield incl covers the whole setup.
Hmmmm... Pm me NIGGAHHHH
Goal of the build is a nice cruiser with balls.. Gonna be stripping the interior tonight.
1329694616[/url]' post='6242686']
Pass us your Driver Dynamics Track day Aaron if you can't get your car ready in time :D
Saw the SAU Nats DVD last night, was all right :thumbsup:
Going in on Wednesday ... Should be fixed before the DD day
Just go for modest power unless you plan on putting in a larger displacement engine. Any RB20 with balls = pain in the ass to drive around town and a 5000rpm powerband, although cool for motorsport, is next to useless on the road.
Guess again...I want you to do 500-1000km of normal driving on those new bearings before you go thrashing my gearbox around a track day. The last guy who did that on a freshly reconditioned box cooked the bearings and ripped every tooth off the third gear cogs = no warranty.
http://www.heraldsun.com.au/news/more-news/wrong-way-caravan-busted-on-west-gate-bridge/story-fn7x8me2-1226274928926
Some guy this morning driving with a caravan driving onto on-comming traffic for 12kms down Westgate and Monash Fwy.....lolwut
http://www.heraldsun...2-1226274928926
I bet he gets off with no vehicle impound and will be charged with careless driving, also no loss of licence
Hmmmmm..
If I'm gonna go through the hassle of a larger engine I might as well build something good and drop it in.
Sif, they'll say that an import careened him onto the wrong side of the road and that Vicpol are looking for suspects and planning several operations to protect the people.
Do you know what the sad thing is? Reading back on this ridiculous analogy, and realising it isn't even far from the truth.
2535 is a bit of a headache but nothing wrong with a 2530 on streets with 210kw.
This wednesday right? If so, his got a good 3 weeks to do that. 1000km in 3 weeks is easy, for me anyways...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
