He was talking about bike gearboxes Pat...not a good idea to do it in synchromesh car gearboxes. You can get away with it but it will wear the dog teeth on your synchros faster.
You can get a "quickshift" for motorbikes that cuts your ignition momentarily as opposed to you rolling off the throttle during a gear change, it's suppose to make clutchless upshifting much smoother. Personally I just use the clutch..it's still fast as hell and you're talking tenths of a second in difference between clutch and no clutch. The slowest part of changing gears in a car is the gearshift itself, which is negated by how quickly you can change gears using a foot lever on a bike...as long as your hands are quick you can be fast with the clutch.
sorry i forgot this was a bike forum :domokun:
:cheers:
The GPX was the only 250cc bike to complete some notoriously hard 10,000km rally that most bikes can't finish without breaking down, if I recall correctly. Can't find the info on it but I think it finished 9th overall, out of like 100 bikes.
i made that mistake too...
but i'm going for an old ninja... when i find the cash..
eh tj, how reliable are they?
So far so good, old issue I had recently was a fried spark plug and a small issue with the carb, but that's becuse i put 98 fuel to clean out the system so drained that all out, kinda jammed the jets in the carb. Other than that I ride this thing hard as!
If you kinda on the heavy side, the rear is a little soft or my shocks are gone, next thing I have to look at, bikes done 18,000 think their due anyway
i'm 68-70 kg, so not that big.
but i guess, i shouldn't be looking at those that's done 30+k kms huh.
All depends, if things have been replaced and the majority of the bikes engine is under 10, why not, I got mine at 14000 for $2800 the dude even rode it from Geelong to drop it off :)
probably start shopping for a bike next week
Anything in particular to watch out for? Or just the same as inspecting a car?
Try and take someone with you who knows bikes, they are a different breed. Some guy put up a good guide in here: http://www.skylinesaustralia.com/forums/topic/391934-bike-inspection-tonight/
yeah, will just pull someone along to go inspect.
still need to find the time to go for the course.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
