fair connection
Hardware is Fast Ethernet, address is 000e.8373.7618 (bia 000e.8373.7618)
Description: Telstra Bigpond Cable 10mbps
MTU 1500 bytes, BW 10000 Kbit, DLY 100 usec,
reliability 255/255, txload 11/255, rxload 226/255
30 second input rate 18957000 bits/sec, 1633 packets/sec
30 second output rate 459000 bits/sec, 811 packets/sec
Bad conclusion at philip island historics. Possible fatality as driver ejected from car after coming unstuck in last corner before straight and hitting the wall. I hope david is ok.
Not to mention all the skylines retiring from the second run.
Looks like good weather tomorrow.
If anyone is interested might be doing a black spur run tomorrow with lunch a bit further up.
If anyone else is interested let me know.
Come to Winton you pony!
6 RB's, 9 SR's, and at 370z entered thus far.
