you have a lotus now?
Bahaha I knew ages ago when I was eaves dropping at rockkung meet few months ago... xD Didn't want to say anything thoughh.
You end up getting that TI exhaust for it shan? And did they talk you into buying any carbon parts?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
