Does series 2 diff have abs plug? Need to know who do I ask!?
Yes. As long as the car has ABS. I think most or all series 2 would have had ABS.
Series 2 diff will have a longer pinion shaft and nose (diff housing) to accomodate the sensor, thus ABS and non-ABS diffs aren't interchangeable unless you have the corresponding tailshaft too.
Yeh that's why I wanna make sure it's right it's deffs series 2 which I think everything has abs from at least 95 on wards
I recon it's gonna be killer mo....
don't listen to these bike riding fags
We're only giving him motivation to prove us wrong, and in jest. He'll learn a lot more about cars from doing something like this than he could learn from reading forums, so an off the record thumbs up to him.
Whatever go fetch my car
pretty light pat what's it meant to be 1320? I guess add fluids / fuel makes sense..
put my boat on?
Yeah 1320 sounds right. 1480kg and the 210kw atw I had puts my car into 150kw/tonne haha
Unfortunately it would be hard convincing security to put a non employee car in the weigh bridge :(
If u were beyonce I'd put a ring on it.
Pat I thought u work for C@dbury?
Yeah I do. As an engineer for the factories. Some of the work perks is trying out the weigh bridge haha
What were you thinking?
We told you not to get an older bike brah..
please dont hurt me! :D
nah but seriously, fix it - get your full license and buy a bigger bike then if you still want one :D
Pat - haha all good it'd probably break the scales :P you work on making machines more efficient yeh? Apparently I'm an engineer as well but a complete different kind.. to be honest I don't really see how I.T folk should be called 'engineers'.. just a title I guess.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
