nah just when you said about factory was confusion.
i'm not adverse to free cadbury marble chocolate blocks having said that.
Haha chocolates gotta be made somewhere :-P
Unfortunately blocks are made in tasmania. I only deal with the chocolate bars.
Pat - haha all good it'd probably break the scales :P you work on making machines more efficient yeh? Apparently I'm an engineer as well but a complete different kind.. to be honest I don't really see how I.T folk should be called 'engineers'.. just a title I guess.
Yeah a part of it. My job is to make the process more efficient. Can be the equipment or method.
Yeah the engineer title is a funny one. Anyone can use the title regardless of having a degree. People have tried to fight it in court but it's a losing battle.
why no-one enter deca????
Can I do it on my bike?
sick of my non working 250
so tempted to replace it with one of these http://firesport.com.au/04-honda-cbr-1000-rr-fireblade-motor-bike-250-750-1100--ad213610.htm
Shoulda got a new ninja ;)
Apparently I won the hottest gf thread, surely I get a prize..
The satisfaction of knowing that all the sad kents in that thread are furiously fapping to her photo
Lol, dare say there was some slight bias in the judging, good to know adz wants my mrs..........
Looks like Matt has a partner in crime then.
There's Something About Sandra (?).
fkn lol.
good work dez.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
