what nuts? i've got a set of used bbs nuts somewhere in the shed dont even know how i got em
The ones that the bolts are torqued to hold the barrels and centers together
they came in today anyway, so start rebuilding over weekend :D
Sway bars aren't a necessity?
If tight on money just get a bigger rear sway bar, you get more out of that in a FWD than most other suspension mods.
Yeah will be getting a Type R sway bar for the back along with a subframe brace (or else my subframe will be destroyed apparently..) Looks like I can hold off the front ones for a while.
http://www.timskelton.com/lightning/race_prep/suspension/corrections.htm
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
