inb4 Dezz bankrupts Govt with his fat return
Bout f**king time I got something back
Knowing my luck, I'll get f**k all back other than the amount I overpaid due to not being able to claim the tax-free threshold on the new job
thanks man.
i wasnt really happy with the finish of a mates rotas, so i went with varrstoen
you drive a 4 door r32, your in the same category as mohsen therefore your point is invalid.
thanks mann
were they matt black? mine and I think Leigh's (never heard complaints :P) were great in matt black
It ain't luck brah, just gotta know what you can claim, if anything. People with minimal deductions often think they are being ripped off etc, just means you haven't had to spend as much to earn your income
Nah a bronze finish. The spray was abit unco on a few of the wheels. But meh mine a here now no point. I'm really happy with em so hopefully I wot fall into the category pf shattering wheels.
I had work Meisters on and I managed to buckle both fronts so I don't think the price u pay for em has anything to do with it
Won't have to do another one for 5 years unless your usage drastically changes :thumbsup:
Also have a soft spot for 335i. Modern day skyline. 3.0L inline 6 twin turbo and from what I hear simple tune, exhaust etc can bring it near 300rwkw
325i coupe - $90k driveaway
335i sedan - $100k driveaway
335i coupe m sport - $130k driveaway
M3 coupe - $170k driveaway
nah it doesn't a broken wheel is a broken wheel no matter what it cost you
335s are dropping because people are anticipating the release of the new F series coupe. Even though that seems quite some time away.
So I'd say it is a good time to buy. Spend a few thousand on this site: http://www.burgertuning.com/ plus labour, you're looking at an easy 300rwkw. (I'm talking the older n54 engine, the n55 still has good gains but not as high being a single).
If anyone wants a ride in a tuned 335i hit me up!
Might take you up on this, I got a friend who is pretty interested in buying one and modifying it. Be good to let him know how they go with a bit of work.
and you and your ATO buddies can smoke me :thumbsup:
What area in the ATO do you work in Ric?
+ 1. I would say if I ever decided to grow up the 335i is on the list of cars to get.
Though us east siders will have to travel to the west lol
I'd get a second hand one not a new one :D
Difference Between me and mohsen is I drive mine
Also your car is bright orange, your opinion of my opinion is this invalid
Just shit stirring anyway I don't care who runs fakes as long as I don't hang out with them haha
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
