FYI Aaron
Gripshift&slide posted a pic of your car on facebook.
All these different guys kept on thinking its some other guys car. Probably the one you showed me in the pic last weekend
Link? I had evo 6 recaros but now ark design sparcos? Are u sure it's not from the adgp? There was a replica there
Quote them this
Paint code is
Arancia Calafornia MICA with a yellow pearl. yes its Busta's and Wades old car. used to have the Evo 6 recliners but they didnt pop forward and a cop told me to change em, so it was an excuse to put some nice® seats in.
and its on varrstoens now because i buckled the works on em.
Quote them this
Paint code is
Ok will do mang
Is 'Arancia Calafornia MICA with a yellow pearl' lamborghini orange paint? Or were you drunk and telling me fibs at your bday?
Edit:
Cot dayum. Nick your too quick
Ok will do mang
Edit:
no idea any more. i was told that. dont really believe it anymore as i was also told the car was sprayed back to metal and re painted. yet stone chips prove that the car is still red lol.
i got a receipt. but, anyone can photocopy a receipt.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
