lets call it IT security
Not specific enough, send me a PM lol. Pretty lucky though, even if it's work, most people have to pay thousands for that kind fo worldly experience :)
'Travelling the world, internet security'
More like I work for M.I.6 and go by alias's such as James Bond, Ethan Hunt, Jason Bourne etc...
Katies friends referd to me as Cody Banks for the first year we dated!
I call it IT security as it a bit of a small field not many ahve heard of.
I Deploy a solution for banks/governments mainly that allows them to know who is actually on the other end of the computer.
It's called PKI and it's basically an online passport.
to date work has sent me to :
England
France
new zealand
Vietnam
Hong kong
Macau
Philippines
South korea
Wales
Ireland
Morroco
USA
Germany
Brazil
Argentina
Italy
Vatican city
Sweden
South Africa
My work has sent me to Epping and brunswick
Also lol'd, well played Dezzeye.
I'm going to wear matching shirt and pants next time we meet up too
lol orange?
or your birthday suit
I'll fight you till death
This is what came to mind
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
