damn I wish I had orderd a BRZ quickly
http://www.carpoint....63801&silo=1011
that's a lot of mark-up for a demo model
What are the dealer's quoting for the BRZ?
Just go the Toyota. There about $37K driveway from a few dealers
lol i realise studio and live are different... i'm sure andrew didn't fill the stadium with 11ty billion reference monitors ;)
that's only 1 area of his job lol - poor kid gets worked to the BONE for like $75k (problem is he loves it)
Remember I was a dj/nightclub promoer and involved in studio production for a decade and have toured pretty much every major dance music producer (well the pre 05ish ones anyway) and eveyone has been phazing out ns10's since the early 2000's. we had 2 sets in our studio, and moved 1 set into the loungeroom. there is still 1 set in the studio that gets used for production, but not the final mixdown
ns10's are good reference monitors for production no doubt, but the reason for them being where they were in the industry was moreso that they dont have the best sound, and if your music sounds good on ns10's then it will sound good on anything.
if you want reference monitors for listening, then there are better options is what i'm saying.
you should hear these new ones that andrew bought man.... somewhere in ther region of 5k... they sound amazing
Thats exactly why i like our ns10 because we are 1 of the few that can make audio sound great on them. I think birds wants to do some recording(mixing) as well. We organised him with a simple studio setup to help him get going.
Link me tk the 5k rig he got? And which audio company is he working for/with
dealers cannot quote for the brz online sales only, but a few "major" dealers got a test drive one.
ie docklands will prob have the only test drive one in vic.
but as they sold out for 2 years guess this one thought make a profit
meant to be around 37-38 drive away.
In this mornings news:
http://www.heraldsun...x-1226451615843
Why do girls make up stuff like this shit?
http://www.heraldsun...w-1226451490649
Didn't happen at my school...
girl wants to feel loved.
teacher likes little boys
Charges should be laid against the attention seeker, should be a deterrent to other people making up false claims like false accusations against teachers etc. Waste of police presence, if it was anyone but a school girl they'd cop a large fine for it.
he's the project manager for these guys... they have SERIOUS audio gear man... the warehouse is truly fapworthy
http://www.norwestproductions.com/
as for the ref monitors he has i'll have to ask him... all i know is they sound phenominal
P.a?
R&d is tech role unfortunately. Food science etc.
I believe the marketing, sales, engineering and it roles are filled.
Any grad positions available for mechanical engineering Patrick?
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
