Bout time wasteland fired up again
For the record ash is probably the most normal of the mods..
Disclaimer - I take it back if you banned me previously :/ haha
I didn't realise it was firing up? Thought he was actually joking. :/
haha nah i didn't ban you, that was C i do believe. Dezz copped it from Nick. Actually I can't recall the last person i legitimately banned (save for Pat). Usually just giving spam-bots the flick which isn't really banning as it's probably just nigerian scammers haha . IPB upgrades still haven't fully worked :(
Well if looking for basic stuff I would start with something Like:
http://www.bunnings.com.au/products_product_kincrome-55pce-14-38-socket-set-tin_12552.aspx?rangeid=134&searchByTerms=false&search=+&filter=brandname--Kincrome%2c%2cSidchrome&page=8
atm I Have this:
http://www.justtools.com.au/prod3119.htm
but I have added much more to it like ratchet spanners, security bit's, extensions, compression tester,
great fun lugging it to track days
need a torque wrench next just been lazy.
Rusted?
DAFUQ you on about? Mine had no rust!
Lol duno, guess it was driven around the north island where they put salt on the snowy roads :\ still drove fine and all that but put me off a bit anyway
WTAC I think only fun if you know ppl driving and can hang..or better yet driving yourself.
My wedding will clash with next years..
started shopping for 2014 WTAC tho,
thinking 300ish cut some weight, lots of aero, and flar the f%^k out fo the guards to get biggest rubber I can..should be fun
295's, it's the only way to fly...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
