I understand the rocking up to work bit, I use to feel a bit weird when people stared / greased me off in my old car still that wasn't the main reason I sold it I just couldn't be f**ked with the cop stress around Knox and as you said got over driving it.
Whats the chances of a work car? wouldn't they let you know when you started?
dem rims: what are they?
Let the old people drive their camry's. They hating cause their wife makes the car choices haha
It's meant to go in my name later on - how far thats true and whether he actually will put it in my name is a different story.
That's gonna cost a fair bit to do
+ 1
Not 100% sure. But there will be stamp duty costs. So unless his going to pay $10K + to transfer the property, and there will also CGT Tax consequences.
oh wells
Lol ok so your all saying that I shouldn't sell my car to benefit others by being able to have them as passengers..
But on the other hand you don't want me to sell because you think it's not a good idea.
Why can't the reason I want to see the car, is because I just want to?
And it's my dad, lol I couldn't care who's house the name is in. I'm pretty sure I'm raised by them for 22 years without any expense from myself so if this is the least I'm doing then so be it.
SSOOOOORRRYYY if none of you have positive relationships(or enough of to one) with your parents to help out a little bit
Dw man we still love ya :P
Lol stop bring a girl and over analysing everything
Just giving out free tax advice brah
Always good to be aware of what you can and can't do
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
