can someone scan their motor magazine and post pics?
Got a few modded fords and holdens too
One of the fords had 558rwkw. Yet still a few seconds slower than a 100rwkw 86 :P To be fair its a small track
LOL had to look twice at that before i realized.
haha yeah ofcourse it would do shit on a small track! Wonder what it would do around PI :P
Those kws are for dyno queening
Yeah pretty much or drag spec, assume its the 5.0l coyote?
So the s3 is good? Full review please. I'll consider buying your bike
Not sure if serious
Was that 3? My 4 has been only phone to last me 2 years with zero problems I use my phone flat out to
Had 3 and 4 both froze a lot as well as other issues
Hooked on frontline commando sick game and works perfectly on my android
A+
Will sus it out, I'm over temple run
friend asked me to go get motorbike license with him in a couple of weeks >,<
tempted!
Do it.
And buy my bike
<3 varrstoens
Dooo ett! Matt black. kgo
Yeah no doubt. Disappoint with the 86 1/4 time though. 13.98 with 168rwkw.
Haha only issue is apparently they dont clear brembos in the sizes I'm looking at.. I dont have brembos yet but was looking at them down the track.. hrm.
And yeah, light stiff car = hard to get power down not designed for drags I guess
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
