isn;t that the point of life? to enjoy it?
Yeh but most people have obstacles to get to this point, and littl obstructions on the way.. You seem to just get the good end of every fkn stick.
Ill kill you one day lol
Position available for internal communications advisor.
Responsibilities include publishing daily corporate news on intranet, writing quarterly newsletters, manage communications, corporate video production etc.
Requirements;
Good verbal and writing skills, print and video production processes, basic idea of photoshop, project management.
If interested, shoot me a Pm.
Sounds like a fun job
Requirements;
I'd hit this but I know nothing about print/video production. The other stuff sounds easy enough.
